Unifi G4 Doorbell Pro - Button Press Event
I have the Unifi G4 Doorbell Pro and I am trying to set an automation that is triggered when the button is pressed (to play the chime through my Sonos).
I have set this up following the below linked guide but it is not working as the initial event is not being triggered.
Looking at the logs the binary sensor never changes from “off” when the doorbell button is pressed. I have monitored the events whilst pressing the doorbell button and I can’t see anything being triggered.
Does anyone else have this issue? Is the Pro not compatible with HomeKit yet?
Hi James,
I have had this working for almost a year with a G4 doorbell. (not the PRO)
I followed the same guide and was very pleased until about 10 days ago when this stopped functioning an I cant for the life of me figure out why.
As far as the Binary sensor goes, I have it set the following way
platform: state
entity_id:
  - binary_sensor.front_door_doorbell
to: "on"
hope that helps.
I had the exact same issue. Did a bunch of digging but based on homebridge-unifi-protect/Troubleshooting.md at ea1c878b621c5e4bbb6cf1c0f32ce8cd70793b9e · hjdhjd/homebridge-unifi-protect · GitHub tried to check for additional info. Turns out my clock between Unifi Protect and Home Assistant was off by 1 min. (HA was ahead) - after re-syncing with an NTP server things started working again, magically. - I am still not 100% convinced timing being off is the issue, but worth checking.
Fully agreed! - Debugging though was a pain. If I may recommend an improvement? Maybe throwing a warning in the event log if such a case is detected vs silently ignoring it?
And I will also fully admit, I should never assume things are synced to NTP without verifying :slight_smile:
I hear you! - Thank you for the clarification!!! :slight_smile:
For some reason I don’t have that binary sensor for a button press at all:
What am I missing here?
Same issue here… Had a G4 Doorbell which died on me… ordered the G4 Pro doorbell but missing the needed entity :man_shrugging:
Same issue here, looking for the entity also
OK so I fixed it. @mrmannetje @martijnDutch
My local user did not have all the permissions. I created a new role in Unifi OS
Gave it those permissions, added the local user, and reloaded the integration and bingo
Then I had the sensor
@robsewell, thanks!
Works like a charm now!!!
Sorry to resurrect this but I’m having the same original problem of HA not even seeing the event of a button press. I’ve already gone through and made sure the time was sync’d so I do not believe that is the issue. Any other known issues that can come up and prevent it from working?
Thank you.
Any traction on this one? I noticed that my doorbell presses stopped sending automations and I just got around to checking it and sure enough, it’s missing. Reloaded, Re-added, changed Perms…ect
Still missing :frowning:
G4 Pro (Non-POE)
Protect 2.9.42
HA 11.1
am seeing the same - was working fine for 6months - not sure whether Protect or HA upgrade broke it but cannot get it working again - not even sure the event is detected by HA anymore - plenty of other events but not doorbell pressed (annoying done have comparable logs from before)
G4 Pro (POE)
Protect 2.10.11
HA 2023.12.0 (also tried 2023.12.1,2023.12.2,2023.12.3)
2023-12-20 09:38:56.724 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:01.725 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:06.725 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:11.726 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:12.558 DEBUG (MainThread) [homeassistant.components.unifiprotect.data] Updating device: G4 Doorbell Pro (E438830C38CD)
2023-12-20 09:39:12.561 DEBUG (MainThread) [homeassistant.components.unifiprotect.select] Updating dynamic select options for Doorbell Text
2023-12-20 09:39:12.633 DEBUG (MainThread) [pyunifiprotect.data.bootstrap] last_ring for 643e2e7a01aee103e4005fb7 (True)
2023-12-20 09:39:12.633 DEBUG (MainThread) [pyunifiprotect.data.base] Event ping timer started for 643e2e7a01aee103e4005fb7
2023-12-20 09:39:12.633 DEBUG (MainThread) [homeassistant.components.unifiprotect.data] Updating device: G4 Doorbell Pro (E438830C38CD)
2023-12-20 09:39:12.634 DEBUG (MainThread) [homeassistant.components.unifiprotect.select] Updating dynamic select options for Doorbell Text
2023-12-20 09:39:13.826 DEBUG (MainThread) [homeassistant.components.unifiprotect.data] Updating device: G4 Doorbell Pro (E438830C38CD)
2023-12-20 09:39:13.826 DEBUG (MainThread) [homeassistant.components.unifiprotect.select] Updating dynamic select options for Doorbell Text
2023-12-20 09:39:15.634 DEBUG (MainThread) [pyunifiprotect.data.base] Event ping callback started for 643e2e7a01aee103e4005fb7
2023-12-20 09:39:16.727 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:17.411 DEBUG (MainThread) [pyunifiprotect.websocket] WS Timeout loop sleep 29.99984071799554
2023-12-20 09:39:21.727 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
2023-12-20 09:39:26.729 DEBUG (MainThread) [pyunifiprotect.api] Skipping update since websocket is active
got around this by swapping the automation to trigger on change “G4 Doorbell Pro Last Doorbell Ring”
I’m headed down the same road again and looking for something on the event bus I can use from the doorbell press on the G4 pro
Certainly Building a sensor to pick up on the last doorbell press would work, but there would be a delay
Anyone else find any other solutions?
Hi friends,
Boo - I’m having the same issues here with G4 Pro POE.
(no history of button press at all.)
Anyone found a new workaround.
Was thinking maybe seeing if I could detect a “chime” from the chime.
Curious how the automation would be crafted using either the UP Chime device or entity? I can see the UP Chime Last Ring, in a date and time format.
Update: Aha. I asked Grok, and got some good advice.
alias: Doorbell1
description: ""
triggers:
  - entity_id:
      - sensor.up_chime_last_ring
    trigger: state
conditions:
  - condition: template
    value_template: >-
      {{ (as_timestamp(now()) -
      as_timestamp(states.sensor.up_chime_last_ring.last_changed)) < 2 }}
actions:
  - action: light.turn_on
    metadata: {}
      flash: short
      device_id: 90a3 . .
    metadata: {}
      flash: long
      device_id: b74a . .
mode: single
Use event instead of the binary sensor. It’s also documented like this in the
Home Assistant Manuel for unify Protect…
triggers:
  - event_type: state_changed
    event_data:
      entity_id: event.haustur_turklingel
    trigger: event
conditions:
    value_template: |
      {{ 'ring' in trigger.event.data.new_state.attributes.event_types }}
Recently replaced my Ring doorbell to a G4 Doorbell Pro (WiFi) and I wanted to keep the same Alexa notification feature of “Someone is at the front door.” I combined all the echos into a speaker group named “everywhere”.
alias: Front Doorbell → Alexa announce (all Echos)
description: ""
triggers:
    event_data:
      entity_id: event.g4_doorbell_pro_doorbell
    trigger: event
conditions:
    value_template: |
      {{ trigger.event.data.new_state is not none
         and trigger.event.data.new_state.attributes.get('event_type') == 'ring' }}
actions:
  - action: notify.send_message
      message: Someone is at the front door.
      entity_id: notify.everywhere_announce
mode: single
max_exceeded: silent
