Unifi Integration: Ability to control Traffic & Firewall rules
It would be great to have ability to turn on (resume) and off (pause) individual Traffic rules that are configured in the Unifi Controller through the Unifi Integration.
There is an option to turn on and off DPI rules, but this functionality has been moved to the new Traffic & Firewall rules, and is stated that will be discontinued in future Network Controller updates.
This would enable automating i.e. kids restrictions, etc.
I’m thinking for every rule there should be a switch created by the integration, which controls Enabled flag for the rule. This is similar to the existing DPI rule functionality, which will be discontinued in future releases.
Bad timing.
Unify just updated their firmware and you will be lucky to have anything working in a few days.
There is a PR for Traffic rules Add Traffic Rule switches to UniFi Network by ViViDboarder · Pull Request #104671 · home-assistant/core · GitHub unfortunately the author became a parent in the middle of it so no ETA atm.
Great idea, hope to see this implemented.
Traffic rule support is part of 2024.8.0
Any idea how?
This is now possible!
Join in and put that developer effort into the unifi integration :slight_smile:
That’s great.
Was using Node and node-red-contrib-unifi along with Node Red Companion but it was a rather complicated setup and difficult to modify (mostly because I always forgot how Node is supposed to work).
I also found that my UDM would often block instructions due to too many simultaneous request.
This morning I ditched all that and went back to using the Unifi Network integration. However I noticed that only HA → Unifi seems to work when toggling a switch to enable/disable an internet rule.
If I pause/resume the rule via the Unifi app or web site, then the HA’s corresponding switch wasn’t updated.
Is this intended?
Edit: seems to work now, just takes about 10s. weird
Do you guys see all of your firewall rules in HA?
Mine only shows the Traffic Rules / App as well as Routing / Port Forwarding ones. It does not show my other firewall rules (e.g. in LAN-In etc.). What am I missing?
