UniFi Integration - empty entity
IIRC yes related entities to the option should reflect its state after you change it
Sry I don’t understand what you mean. Does it mean they should be deactivated after unchecking the boxes?
If yes they are still active, what can I do to change this.
Would deleting and reinstalling the integration help?
Yes disabling option should disable entities. Try enable/save/disable again.
Thanks! This solved my issue, entities are disabled now.
Tried to enable and disable another time. And now it works fine. So I’m able to enable if I need it. Thanks again.
@segfaultex you should also try this if you still have this issue.
I will take this input with me and try to clarify Integration documentation
I did still have the issue but I ended up just removing the integration.
Although even with unifi removed my devices page looks like this.
My page also looks like this. Even if the integration is disabled and builds those entities.
Hard to find devices that you want to enable in this “no name” list. This is why I enabled them directly in the invisible core.entity_registry (it’s in the invisible .storage folder) file. But we careful if you change something in there.
I think you can get rid of these entries by deleting the section related to unifi (search for unifi).
But as I said be very careful, you can break your ha instance with this.
