New to Home Assistant - I’ve set up the server on a HyperV VM and connected it to my UDM-Pro via the Unifi Network integration.
Connected entities through the Unifi integration are continuously connecting and disconnecting roughly every minute. I think there may be an issue with the websocket but I’m not sure how to troubleshoot this further.
Troubleshooting so far:
HA setup - created a new VM (running on Hyper-V created from VHDX). Reinstalled Unifi Network integration. Time until considered away increased to 900 seconds.
Wireshark - no packet loss seen
Firewall - Rule made to allow from HA server to firewall on port 443
UDM logs - shows Websocket dropping:
[2022-10-18T11:55:19,715] <ws-notify> WARN api - unable to send over websocket java.lang.IllegalStateException: The WebSocket session [49ef] has been closed and no method (apart from close()) may be called on a closed session
[2022-10-18T11:55:37,458] <webapi-4783> WARN api - websocket session error:Connection reset by peer
HA logs - Also shows Websocket dropping:
2022-10-18 10:34:03.247 WARNING (MainThread) [homeassistant.components.unifi] Lost connection to UniFi Network
2022-10-18 10:34:09.761 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [140499567899072] Connection closed by client
2022-10-18 10:34:28.867 ERROR (MainThread) [aiounifi.websocket] AIOHTTP websocket error
