Every now and then, the Unifi integration needs to reauthenticate.
With MFA enabled, it is impossible to do so without logging on to https://account.ui.com/ and disabling MFA. Only then does it seem to work…
This is a problem as it effectively means generating a whole new token when re-enabling MFA, which needs to be reintroduced to the OTP managers (Authy, Google Authenticator etc.)
The integration probably needs to have a second step to enter the new token…
Any ideas if this is already resolved somehow? Or a workaround not involving the above steps and certainly not disabling MFA altogether? Or an ETA of some fix?
Thanks in advance
