I have a little bit odd issue. I am using the Unifi integration, which is working fine in basic. I configured specific WIFI SSID in the integration to track wireless clients on. I enabled ‘follow network clients’.
I did disabled the option to automatically create entities in Home Assistant, otherwise a lot of entities are created which i am not using.
Problem here is; when for example a client is connected to 1 of the SSIDs, i do see it in the entity list as a Disabled Entity. I can enable it and all working fine.
But somehow this entities are disappearing. As a device and as an entity. Probably when the device is disconnected.
Now the next time the client is on the network again, i do have to enable the entity again.
How do i solve this?
