hi everyone,
I’m experiencing a very weird issue with my unify network add-on.
The state shows that it’s stopped (only “Start” button available and red dot in the upper right corner) but it’s actually running and working perfectly fine.
the add-on log doesn’t show any error
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: UniFi Network Application
Manage your UniFi network using a web browser
Add-on version: 2.7.0
You are running the latest version of this add-on.
System: Home Assistant OS 10.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.8.3
Home Assistant Supervisor: 2023.08.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[07:01:49] INFO: Configuring timezone (Europe/Vienna)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-unifi: starting
s6-rc: info: service init-unifi successfully started
s6-rc: info: service unifi: starting
s6-rc: info: service unifi successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[07:01:50] INFO: Now starting the UniFi Network Application...
[07:01:50] INFO: Note: No add-on specific logs beyond this point.
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/usr/lib/unifi/lib/tomcat-embed-core-9.0.65.jar) to field java.io.ObjectStreamClass$Caches.localDescs
WARNING: Please consider reporting this to the maintainers of org.apache.catalina.loader.WebappClassLoaderBase
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Unfortunately this means that the watchdog function doesn’t work, meaning if I restart my HA host (rasperry pi 4B) or the add-on crashes, it won’t automatically restart.
HA logs don’t show anything regarding this integration.
Again, the add-on works just fine and is available via https://<rasperry_ip>:8443
Does anyone have an idea what the issue might be?
Thanks in advance!
