The current Unifi Integration allows for PoE contol of a port, but it would be nice to be able control the state (enabled/disabled) of a port on a switch.
It is possible to control the state via CLI on the switch – by using Cisco commands.
I too would like more control over the ports themselves aside from the poe. If possible the enable/disable mentioned here at minimum but also vlans as well would be super nice.
did this ever get added? I see where it says port control is a switch… but when you add it, it does not control the port. It will report the port status as on or off if you disable it in the app, but the HA switch has no effect.
I can use the switch in HA to disable a Port. It Takes a while for HA to get the switch state. However, I cannot enable the port again within HA. If enabling with HA the port will be active in the unifi network app, but missing the default Network and VLAN. The client will stay offline until I disable the port within unifi network app and enable it again. Not sure if I have the correct wording(activate, enable)
