I recently updated my home assistant instance and added the new controls for the poe ports of a switch. It works perfectly with the new Access-points that are powered over the lastest poe/ poe+ standard.
Nevertheless, I have two older access points which are supplied by passive 24v poe. When I switch the port to off, the poe on that port is correctly turned to off. When I switch the port back to on, the unifi integration turns the port on but with the wrong poe standard (poe+/ poe instead of passive 24v).
I already tried a port profile with passive poe as a standard but this doesn’t work either.
