Here is my log. Fails with ai pro, works with g5 dome…
Blockquote
Logger: homeassistant.components.websocket_api.http.connection
Source: components/unifiprotect/media_player.py:137
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 22:40:44 (5 occurrences)
Last logged: 22:46:49
[140298676725232] Error handling message: Unknown error (unknown_error) Roberto from 192.168.0.9 (Mozilla/5.0 (Linux; Android 14; SM-S916B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/135.0.7049.37 Mobile Safari/537.36 Home Assistant/2025.1.2-14946 (Android 14; SM-S916B))
File “/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py”, line 28, in _handle_async_response
await func(hass, connection, msg)
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 816, in handle_execute_script
script_result = await script_obj.async_run(
msg.get(“variables”), context=context
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 1827, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 460, in async_run
await self._async_step(log_exceptions=False)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 526, in _async_step
self._handle_exception(
ex, continue_on_error, self._log_exceptions or log_exceptions
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 556, in _handle_exception
raise exception
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 524, in _async_step
await getattr(self, handler)()
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 1008, in _async_step_call_service
response_data = await self._async_run_long_action(
…<9 lines>…
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 624, in _async_run_long_action
return await long_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 2794, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2837, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1079, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/tts/entity.py”, line 129, in async_speak
await self.hass.services.async_call(
…<17 lines>…
result = await task
File “/usr/src/homeassistant/homeassistant/components/unifiprotect/media_player.py”, line 137, in async_play_media
await self.device.wait_until_audio_completes()
File “/usr/local/lib/python3.13/site-packages/uiprotect/data/devices.py”, line 2575, in wait_until_audio_completes
raise StreamError(“Error while playing audio (ffmpeg): \n” + error)
uiprotect.exceptions.StreamError: Error while playing audio (ffmpeg):
Input #0, mp3, from ‘http://192.168.0.238:8123/api/tts_proxy/Uh57qTkd8JTa3m0KL-3j7A.mp3’:
Duration: N/A, start: 0.000000, bitrate: 64 kb/s
Stream #0:0: Audio: mp3, 24000 Hz, mono, fltp, 64 kb/s
Stream mapping:
Stream #0:0 → #0:0 (mp3 (mp3float) → opus (native))
Press [q] to stop, [?] for help
[opus @ 0x7fe618fd1000] The encoder ‘opus’ is experimental but experimental codecs are not enabled, add ‘-strict -2’ if you want to use it.
[opus @ 0x7fe618fd1000] Alternatively use the non experimental encoder ‘libopus’.
Error while filtering: Experimental feature
[out#0/adts @ 0x7fe618be03c0] Nothing was written into output file, because at least one of its streams received no packets.
size= 0kB time=N/A bitrate=N/A speed=N/A
Conversion failed!
Blockquote
