To provide some additional information, I have a Ubiquiti USG firewall. My cameras are on a seperate vlan from the hassio install. I opened what I thought were the necessary ports but to verify this wasn’t the problem I temporarily allowed all traffic between the vlans while I tested it. Is there any port forwarding or weird stuff I would need to do from the outside to get this stream to show up in hassio?
Anybody have an idea on what thte entity not found error could be when trying to send the stream? To be clear I have tested the rtsp stream in vlc and it works fine.
@gohassgo I changed the name of the camera from
Front Porch
to
Front Porch
trying to see if the space makes a difference. I also changed the entity name to camera.front_porch or camera.frontporch accordingly and this did not change anything. I also verified I can stream from a Nvidia shield on the same vlan as my hassio raspberry pi from the camera on the other vlan. This verified it is not a firewall issue.
@kymnyth You can look on my GitHub, for an example. I have just updated my raw config of my lovelace to Github. I’ll push the rest of the config to github in the next few hours when i return from work.
You can use this example to assist you with installing custom components for Lovelace. There will also be many posts on the forum for installing custom JavaScript.
I restarted everything tried to connect to the stream and look the logs again. there are no errors and it says it’s starting the stream but I’m not getting any picture. I’m running this on a raspberry pi, is it possible it’s just too underpowered to act as a proxy for the stream?
I am also running a similar setup to you. I am running all my infrastructure on another VLAN to Hasiso however I am using PFSense and Hassio is a container on an Intel NUC Gen7.
What is the controller for you Unifi camera?
I’ve updated my Github with all the settings I am using.
I am using the CKG2+ with Unifi Protect. The reason I was questioning the ability of the Raspberry Pi 3 to keep up was due to the fact a direct stream works but not using the hassio as a proxy for the stream to a browser.
@noodlemctwoodle My configuration is identical to yours and I did try and connect to homeassistant on the same subnet and I’m still unable to see the stream. The snapshots have worked from the beginning. I appreciate your help.
@noodlemctwoodle Here is a description of the testing I have done from a network/firewall perspective.
I have 2 subnets IOT and MAIN.
HASSIO is on IOT my cameras are on MAIN.
My original firewall rules drop all traffic from IOT to MAIN except specific ip address/port combinations that are required (example: access to my plex server from my tvs/shield).
Originally configured firewall rules:
Accept tcp/udp access from my HASSIO (10.8.7.7) to my cameras (10.10.10.X addresses) for snapshot access - this has worked from the beginning.
Accept tcp/udp access from my HASSIO to CKG2+/Unifi Protect (10.10.10.3:7447) - this didn’t allow streams
To verify it wasn’t a firewall rule issue I changed firewall to:
Accept all IOT tcp/udp to MAIN temporarily. - Streaming still did not work from MAIN subnet
through HASSIO, vlc access works from MAIN subnet
I changed firewall to limit a bit while continuing to test:
Accept IOT to CKG2± no access to stream from MAIN network through HASSIO, vlc access still worked
Accept tcp/udp to Cameras for snapshot access - snapshots still work
I thought this may be a firewall issue so I decided to do testing from the IOT subnet. Streamed directly from camera to a computer and my nvidia shield which is on the IOT subnet works both with the firewall wide open IOT-> MAIN and locked down to only have access to the CKG2+ ports and camera ips.
As for streaming directly from camera IP. My understanding is I would have to put the camera in standalone mode which would prevent the use of unifi protect which I would prefer not to do.
