Unifi Protect Integration - Unknown error occurred
I have a weird situation - I have both a Unifi UDM SE and a Unifi NVR. All of my cameras are connected to the Unifi NVR through Unifi Protect (latest version as of today - 5.3.48). When I try to use the Unifi Protect integration in Home Assistant I get an “Unknown error occurred”??
I’ve setup a local user on the NVR, given it Super Admin permissions - still no joy.
But here is the weird thing - I installed Unifi Protect on my UDM SE, and then removed one of the cameras from my NVR and adopted it into my UDM SE through Unifi Protect, then used the Unifi Protect integration in Home Assistant and connect to my UDM SE - bingo, it all works!
I’m running the same version of Unifi Protect on both devices, I just don’t get it.
Anyone have any idea what I might be doing wrong? Some sort of config on the NVR that I need to add/change?
Any help will be greatly appreciated
IIRC there is something a little unintuitive with this setup. Then NVR needs to adopt the udm. Then you can use the the udm user to log into protect and see all the cameras.
Unintuitive? It’s the most basic standard Unifi setup going?? I think your suggestion of the NVR adopting the UDM is incorrect - I think you mean the UDM adopting the NVR, which I have already done. Therefore Unifi Protect is shown in the UDM dashboard, but of course it is being run on the NVR.
Like I said this is a standard unifi configuration - absolutely nothing unusual here. But I just cannot connect - I keep getting “Unknown error occurred”??
No the opposite way around, that’s why i said unintuitive.
I don’t understand what you mean? The NVR adopting the UDM is not an option - the only option is to “merge” the two consoles and the precedent is the UDM control plane.
If you are getting confused with the Protect app, then I can confirm that Unifi Protect is ONLY running on the NVR - there is no Unifi Protect running on the UDM. When you have an NVR the best practice (as per Ubiquiti) is to run Unifi Protect on the NVR and NOT on the UDM.
Please show me where/how the “NVR can adopt the UDM”, I’m happy to be proved wrong - but I just don’t see how this makes any sense??
It’s been a long time since I set up a unvr. Looking online for steps I came across this and it seems familiar. In particular step 4.
Yeah - that article explains the merge process of a UDM and UNVR (specifically migrating cameras from Unifi Protect), whereby you migrate from Unifi Protect in UDM to Unifi Protect in UNVR. As I explained right at the very beginning that’s exactly what I have.
Hi @moonpunk, I experienced same problem. I have UDM-Base and I recently installed UNVR and merged it. Everything works as expected and I have setup the Unifi integration with my UDM-Base console. When I tried to setup Unifi Protect integration with my UNVR-Console then I experienced exactly same problem saying: “Unknown error occurred”. But interesting thing was I saw that integration logged in. I checked HomeAssistant logs and I found where was my problem:
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:481
  File "/usr/local/lib/python3.13/enum.py", line 1201, in __new__
    raise ve_exc
ValueError: 'adaptive' is not a valid RecordingMode
I had 2 cameras set to the Adaptive recording. So I switched them to the Continuous and integration started to work!
Thanks ever so much MyKE - this worked for me too.
Much appreciated
