The live video fromt the Unifi Protect integration, is a bout 20 seconds delayed, and very unstable. For me, the integration is useless as I intend to use it for live video stream.
Does anybody have a fix on this? I need the video to show in the dashboard.
I have installed the go2rtc, the WEBrtc and the RTSPtoWeb - WebRTC. I cant get it to work… First I get a still picture, then I the message: Failed to start WebRTC stream: RTSPtoWeb server failure: stream channel codec not ready, possible stream offline: Internal Server Error
I guess my question is, how do I add the stream in the web UI? Do I click “add” and paste the: rtsp//192.168.1.1:7447/…?enableSrtp ? Or do I have to type in something under the “config” tab?
Thank you for helping me, as you can understand, Im new to this
its been a while for me but just tried to add a new one.
Click Add, then temporary stream, paste it in the url field and give it a name and click add, you should get a dialog box saying “OK”.
Then go to streams and you should see it there. If you click on stream under commands you should see the stream
