UniFI Protect Setup Error
I am having an issue with adding the UniFi Protect integration. I had this setup before and after a reboot the integration would no longer start. I removed from HA and tried to re-add it and now I am just getting “Failed to Connect”. At the end of the log I am seeing this error: “ValueError: year -3025 is out of range” I have checked both by UDM Pro and HA and both time/date are correct.
For added info I am on the latest public release in both HA and UDM Pro/Protect.
Has anybody else seem this issue?
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
First occurred: October 13, 2024 at 3:49:35 PM (42 occurrences)
Last logged: 10:40:49 AM
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/unifiprotect/config_flow.py", line 343, in async_step_user
    nvr_data, errors = await self._async_get_nvr_data(user_input)
  File "/usr/src/homeassistant/homeassistant/components/unifiprotect/config_flow.py", line 271, in _async_get_nvr_data
    bootstrap = await protect.get_bootstrap()
  File "/usr/local/lib/python3.12/site-packages/uiprotect/api.py", line 1177, in get_bootstrap
    return Bootstrap.from_unifi_dict(**data, api=self)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 134, in from_unifi_dict
    data = cls.unifi_dict_to_dict(data)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/bootstrap.py", line 224, in unifi_dict_to_dict
    return super().unifi_dict_to_dict(data)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 353, in unifi_dict_to_dict
    data[key] = cls._clean_protect_obj_dict(value, unifi_dicts[key], api)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 273, in _clean_protect_obj_dict
    return {k: cls._clean_protect_obj(v, klass, api) for k, v in items.items()}
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 254, in _clean_protect_obj
    return klass.unifi_dict_to_dict(data=data)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/devices.py", line 1052, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 349, in unifi_dict_to_dict
    data[key] = cls._clean_protect_obj(value, unifi_objs[key], api)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/devices.py", line 645, in unifi_dict_to_dict
  File "/usr/local/lib/python3.12/site-packages/uiprotect/data/base.py", line 311, in unifi_dict_to_dict
    data[key] = convert(val)  # type: ignore[operator]
  File "/usr/local/lib/python3.12/site-packages/uiprotect/utils.py", line 167, in convert_to_datetime
    return None if source_time is None else from_js_time(source_time)
  File "/usr/local/lib/python3.12/site-packages/uiprotect/utils.py", line 161, in from_js_time
    return datetime.fromtimestamp(int(num) / 1000, tz=timezone.utc)
Any luck here? I am having the same problem.
