I believe the cpu needs to be lower-case as its case sensitive:
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['cpu']
However, that stat is cpu usage, not temperature.
“cpu” lowercase = usage
“CPU” uppercase = temperature
Like I said before… When I setup with uppercase CPU, the value stays empty of the new sensor.
Got a bit further in this:
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['temps']['CPU'] }}"
That gives me the correct temperature! Now I need to figure out how to remove the " C" (with the space)
Does anyone have an idea what to do? I’m not a JSON expert
Took me a while to get there but got it fully working now.
here is the code:
sensors:
unifi_gateway_wan_cpu:
friendly_name: 'CPU percentage'
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['cpu'] }}"
unit_of_measurement: percentage
unifi_gateway_wan_mem:
friendly_name: 'Memory percentage'
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['mem'] }}"
unifi_gateway_wan_cpu_temp:
friendly_name: 'CPU temperature'
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['temps']['CPU']|replace('C', '') }}"
unit_of_measurement: degrees
unifi_gateway_wan_ip:
friendly_name: 'WAN IP'
value_template: '{{ states.sensor.unifi_gateway_wan.attributes.wan_ip }}'
Thanks just what I was looking for.
Hi there. Is it suppose to work in 0.95? Just get updated and get Platform not found during configuration check.
I have the same issue on 0.95.
I have the same issue with 0.95.
We ever get a fix? I thought it was me
I had to disable the sensor this morning until it gets corrected…
I have been watching your PR and I noticed that there has been no attention from the Dev. @jchasey , Maybe he’s AFK enjoying his summer, I am not in that much of a hurry…
Unfortunately not had the time to look into the issue in detail, other than to confirm that I am experiencing the same problem.
I’ve had a brief look at new replacement library for pyunifi that was integrated in the most recent update and it appears that this should be able to be used as a replacement for this component too.
I’ve had an initial look at the issue, unfortunately when in the development environment (0.96) it all works fine, but I can reproduce the issue on 0.95.4 on my RPi running Hassio. It just makes for slower debugging!
Those who are having the issue are you running Hassio ?
I’m running 0.95.4 on hassio on an Ubuntu vm and I have the issue.
I’m running hassio 0.95.4 on an Debian 9.9 vm and I have the issue. The issue started for me at hassio 0.95.0.
I am running hassio 0.95.4 on the Intel NUC build - HassOS 2.12 production build… Also, not sure if it matters, but I am also running the USG Pro4, which in iteself, I found a couple of minor issues when the component was running…
I’m running HASSIO 0.95.4 and this doesn’t work for me.
The common factor appears to be HASSIO which suggests that a change to setup/dependency installation process is at fault.
Anyone NOT running HASSIO that is experiencing the same issue?
I think the common factor is 0.95.x
For me the problems started with the upgrade to 0.95.0
For me it was the upgrade to 0.95 as well.
