Hi All,
I’m seeing a lot of errors for the Unifi Status integration. Can anyone shed some light on where a potential issue may be.
Configuration at the UDM SE side is a local user as suggested in a number of sources.
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:950
First occurred: May 21, 2024 at 7:43:54 PM (10916 occurrences)
Last logged: 1:55:30 PM
Update for sensor.unifi_status_vpn fails
Update for sensor.unifi_status_www fails
Update for sensor.unifi_status_wan fails
Update for sensor.unifi_status_wlan fails
Update for sensor.unifi_status_lan fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 950, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1295, in async_device_update
await hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 191, in wrapper
result = method(*args, **kwargs)
File "/config/custom_components/unifi_status/sensor.py", line 202, in update
if sub["subsystem"] == self._sensor:
TypeError: string indices must be integers, not 'str'
The config is fine and upon checking the graphs, all the data is there.
# UNIFI CONFIGURATION
- platform: unifi_status
host: !secret host_udm
port: 443
verify_ssl: false
version: UDMP-unifiOS
username: !secret unifi_username
password: !secret unifi_password
monitored_conditions:
- www
- wan
- wlan
- lan
- alerts
- firmware
- vpn
