Unifi/Ubiqui SmartPower Strip integration
I have 8 Unifi/Ubiquiti SmartPower strips and assumed (foolishly) that they were supported since other Unifi products are. These power strips maintain a strong connection to the Unifi network but don’t work with Home Assistant out of the box.
The entities appear in HA but the state is not tracked accurately. For example, a switch can be activated via HA. The entity state will temporarly show “on” and then flip to “off.” It would be greatly appreciated if someone could help with this integration. I’m available to test or assist in any way possible. I don’t have the coding/integration chops do this on my own.
Probably more of a bug than missing support.
The documentation doesn’t refer to the device. It says, “switch” but I think that intended to for the rack-mounted devices. I could be wrong. What do you suggest - move it to a bug?
Well all supported devices will never be listed, if you get the entities but their state doesn’t update properly then it’s probably a bug. Report it as a bug
