Hello everyone,
not sure if anyone can help, but I am slowly in the position to give up. Here is the situation:
I was able to setup HomeKit, Unify and Unfiy Protect in HA via Integration
I am able to access all cameras via HA and can see their stream (internal network)
I was able to add the Unify cameras in Apples Home environment and can see their stream on apes home when I am connected via WiFi using my internal network
Here is the problem:
I can not see the camera stream on my iPhone when I use my e.g. LTE network ( disconnected from my home network)
For testing purposes, I have also installed HomeBridge on a difference server and can access the camera stream via e.g. LTE without any issues
6)For testing purposes I also added my myQ garage opener via HA and added it via HomeKit into Apple Home. I can open/close the garage via Wifi or LTE and have no issues. Reason for doing it was to test if I can access the garage opener via Apple Home to test the network and see if this caused the camera issue I am facing above.
Anyone else facing a similar issue or might have an idea what else I could do to?
Thank you for any guidance.
Tom
