Given I am new to all of this, I am not sure all my setups are the cleanest. I am using hassbian and want to uninstall appdaemon and duckdns (go back to local IP only) installs that I did over the weekend and start fresh. I am struggling to find instructions on how to do this. Can someone help?
i don’t use appdaemon so i can’t help there.
but duckdns is a completely external thing. if you don’t want to use it just don’t use the domain name and simply use your local ip address. do note that your local ip is only for access from your local network. if you want to access HA from outside your network you will have to use your public ip address and forward the HA port thru your router. Do note also that you should use some form of encryption if you open that port for your security.
Thanks for the help.
