Hi all,
I’m quite new to home assistant, trying to migrate from iobroker to HA now.
I have unipi 1.1 board which has 0-10 V analog output that I’m using to control the level of my air ventilation system in our house. 0 V would mean 0%, 10 V 100%.
Installed the Node-RED addon and imported the flows from Node-RED instance which is installed as iobroker addon.
I’m not sure about the types of home assistant nodes I should use in order to have input from HA on the one hand:
And input from unipi (Evok API) websocket connection on the other hand.
In iobroker Node-RED I’m just having same object as used once as input node and once as output node so that the level of my ventilation is always in sync:
What are the best nodes to use in HA to achieve the same?
The events: state node seems to work fine with setting the value from HA as a slider and getting it immediately into Node RED.
What node type can I use to write updated value to same HA entity in case the change would happen via Unipi webinterface?
Thanks for your help,
Peter
