matmarius
(Matmarius)
September 27, 2023, 7:00pm
1
I have a house with 4 rooms, each one having 2 electrical wall sockets.
I created in local calendar an event named lets say “room1”:
calendar_event
start_time: 2023-09-25 21:30:00
end_time: 2023-09-25 22:00:00
message: room1
all_day: false
friendly_name: wall_sockets_calendar
I’ve created these arrays:
{% set rooms = [‘room1’, ‘room2’, ‘room3’,‘room4’] %}
{% set switches1= [‘switch.sonoff_1_relay1’, ‘switch.sonoff_2_relay1’, ‘switch.sonoff_3_relay1’,‘switch.sonoff_4_relay1’] %}
{% set switches2= [‘switch.sonoff_1_relay2’, ‘switch.sonoff_2_relay2’, ‘switch.sonoff_3_relay2’,‘switch.sonoff_4_relay2’] %}
Basically what i want is to create an unique automation that will power on the corresponding room switches during an event calendar.
Multiple events can coexist or could overlap on the same period of time.
Is this possible using HA automation?
Thanks in advance.
123
(Taras)
September 27, 2023, 8:21pm
2
When a Calendar Trigger is triggered, the automation’s condition
and action
have access to these properties.
In other words, the word “room1” must be in the Calendar event’s title
or description
property. In the following example, I assumed it will be in the Calendar event’s description
alias: example
variables:
rooms:
room1:
- switch.sonoff_1_relay1
- switch.sonoff_1_relay2
room2:
- switch.sonoff_2_relay1
- switch.sonoff_2_relay2
room3:
- switch.sonoff_3_relay1
- switch.sonoff_3_relay2
room4:
- switch.sonoff_4_relay1
- switch.sonoff_4_relay2
- id: 'on'
platform: calendar
event: start
entity_id: calendar.your_calendar
- id: 'off'
platform: calendar
event: end
condition:
- condition: template
value_template: "{{ trigger.calendar_event.description in rooms.keys() }}"
- service: switch.turn_{{ trigger.id }}"
entity_id: >
{{ rooms.get(trigger.calendar_event.description) }}
matmarius
(Matmarius)
September 30, 2023, 3:36pm
3
Seems is not turning on/off the corresponding switches
I get this Error: Template rendered invalid service: switch.turn_on"
Get rid of the trailing "
