Could the favicon of the frontend be made slightly different from the https://www.home-assistant.io/ pages?
For people like myself with dozens of documentation and forums opened in the browser it would be beneficial if the tab with the UI page would be identifiable.
I understand that while not hard to implement there my be concerns / discussions regarding aesthetics.
Thanks for considering!
Martin
and copied the file to /root/config/www/favicons/favicon.ico
This is the path I understood from the description; similar to where the custom_components reside: /root/config/custom_components/favicon/__init__.py
I must be missing something since the icon didn’t change.
I suspect that the dockerized system has the /www/ on a different path(?) (in a docker somewhere)
When I place the full local path of the favicon.ico to Chrome it does display a black screen with the (desired orange) icon in the middle. So I hope that is confirmed.
I rebooted Home Assistant, flushed browser cache and as a last resort I even launched Edge (that haven’t seen HASS yet).
HOWEVER I just tried to reconfigure the Favicon integration again.
I misunderstood the example and had the base-name favicon in the Icon Path.
Once removed:
While there is a solution for that… I think defaults are important. The HA main website, your own installation and the forums all use the same icon, and you definitely don’t get control over the favicons for the forum and the main site. With 15 tabs open trying to work something out, knowing which is which would be useful straight out of the box and fix the problem for everyone. They don’t need to be totally different, just clearly identifiable (such as outlines or similar).
