Hope you all can help me with the attached error showing up in my yaml config file. I have done quite a bit of reading and I’m not sure that there is a solution. Essentially, I have “wrapped” a philips hue smart outlet to make it show up as a switch entity instead of as a light. I would now like to add that entity to an area within home assistant. I am reading that entities added/ created in the config file rather than by the UI often cannot have a unique ID? Are there any work arounds/ fixes to this issues? . Thank you all for any guidance you can give. (I am a newbie with home assistant in general). Thanks again!! Below is an attempt at the copy paste of the section of my yaml I am speaking of. (It doesn’t like my attempt at adding the unique id property in.-- I am getting an error attempting to fix the issue like that)
switch:
unique_id: projector_power_switch
switches:
projector_power:
value_template: "{{ is_state('light.projector_power', 'on') }}"
turn_on:
service: light.turn_on
entity_id: light.projector_power
turn_off:
service: light.turn_off
