hello, i am trying to give my measure a unit of measurement. This value should actually be one in mm. I now get the measured value well but there is no unit behind it. Can anyone help me get this done
Hello Tom, can you give me an example how to apply this in my situation?
Add a customize include under homeassistant to your configuration.yaml file if it does not exist.
homeassistant:
customize: !include customize.yaml
Create the customize.yaml file in your /config folder and add the following inside it:
sensor.rain_total:
unit_of_measurement: 'mm'
Assuming that sensor.rain_total
is actually the sensor entity_id you need to change the unit of.
thanks thats fixed
