This blueprint sets up a single automation that applies to ALL of the Zooz paddle-style dimmers and switches on your network.
I made this because I replaced all of my switches and dimmers with Zooz devices. My old dimmers and switches supported a delayed power-off feature that I quite liked, where holding the button down for a few seconds resulted in the light turning off after a configurable delay. I wanted the Zooz devices to do the same, but I didn’t want to make an automation for every device. Instead this blueprint will make an automation that applies to all of your Zooz devices. It will accept a scene and event type as inputs (up / down), (on / off / toggle) and a duration.
If you choose, say, “Up”, “Triple Tap”, “Power On”, and “30 seconds”, then ALL of your Zooz devices will support a triple tap up to turn on after a 30 second delay. (Of course, only the device that you triple tapped will turn on!)
You will need to enable scene control for your switches and dimmers for this to work - it is disabled by default.
blueprint:
name: Zooz universal delayed actions
description: Assign a universal action on a delay to a scene event on all Zooz dimmers
domain: automation
input:
scene_number:
selector:
select:
options:
- label: Scene 1 (Up button)
value: "001"
- label: Scene 2 (Down button)
value: "002"
event_type:
selector:
select:
options:
- label: Double tap
value: KeyPressed2x
- label: Triple tap
value: KeyPressed3x
- label: Four-tap
value: KeyPressed4x
- label: Five-tap
value: KeyPressed5x
- label: Hold
value: KeyHeldDown
- label: Release after Hold
value: KeyReleased
action_class:
selector:
select:
options:
- label: Turn On
value: homeassistant.turn_on
- label: Turn Off
value: homeassistant.turn_off
- label: Toggle
value: homeassistant.toggle
delay:
selector:
duration:
mode: parallel
- platform: event
event_type: zwave_js_value_notification
variables:
scene_number: !input scene_number
event_type: !input event_type
condition:
{{ trigger.event.data.property == 'scene' and
trigger.event.data.property_key == scene_number and
trigger.event.data.value == event_type and
is_device_attr(trigger.event.data.device_id, 'manufacturer', 'Zooz') and
device_attr(trigger.event.data.device_id, 'model') in ['ZEN71 800LR', 'ZEN71', 'ZEN72 800LR', 'ZEN72', 'ZEN76 800LR', 'ZEN76', 'ZEN77 800LR', 'ZEN77'] }}
- delay: !input delay
- service: !input action_class
entity_id: |
{{ expand(device_entities(trigger.event.data.device_id)) | selectattr('domain', 'in', ['light', 'switch']) | map(attribute='entity_id') | list }}
