Universal Media Player - HomeKit - No Mute Button
I am still quite new to Home Assistant.
I use a Harmony Hub to control my TV and Nvidia Shield. For this purpose I have created a Unisversal Media Player and configured it accordingly.
I have the media player in HomeKit as accessory.
The player also appears in Home but the mute, play and stop button does not appear.
Maybe someone has an idea?
Here is my config:
HomeKit
homekit:
- port: 55704
  name: Home Assistant Bridge
  mode: bridge
  filter:
    include_entities:
      - switch.mute_harmony_hub
- port: 55604
  name: Harmony Media Player
  mode: accessory
  filter:
    include_entities:
      - media_player.harmony_media_player
  entity_config:
    media_player.harmony_media_player:
      feature_list:
        - feature: on_off
        - feature: play_pause
        - feature: play_stop
        - feature: toggle_mute
Remote
remote:
  - platform: harmony
    host: 192.168.178.35
    activity: Shield
Media Player
  - platform: universal
    attributes:
      state: remote.harmony_hub
      source_list: remote.harmony_hub|activity_list
      source: remote.harmony_hub|current_activity
      is_volume_muted: input_boolean.harmony_hub_muted
    commands:
      turn_on:
        service: remote.turn_on
        entity_id: remote.harmony_hub
      turn_off:
        service: remote.turn_off
      volume_up:
        service: remote.send_command
          device: "Samsung Verst\u00c3\u00a4rker"
          command: VolumeUp
      volume_down:
          command: volume_down
      volume_mute:
        service: switch.toggle
        entity_id: switch.mute_harmony_hub
      select_source:
          activity: '{{ source }}'
Switch
# Input_boolean_mute"
      mute_harmony_hub:
        friendly_name: "Mute Harmony Hub"
        unique_id: "mute_harmony_hub"
        value_template: "{{is_state('input_boolean.harmony_hub_muted','on')}}"
        turn_on:
              entity_id: input_boolean.harmony_hub_muted
          - service: remote.send_command
              command: Mute
        turn_off:
          - service: input_boolean.turn_off
              command: Muteor paste code here
customize
  customize:
      device_class: tv
Entity
Many thanks in advance
Hi, have you found a solution to this? I’m having the same issue, expose Harmony to HomeKit, everything works except for mute_toggle and play/pause.
If it works for you can you share the config? Thank you very much!
