Love this thing, now trying my best to make it look pretty. Is there a way to change colors of individual default buttons (spotify green, youtube red, etc)? I figured out the css style for the custom buttons, but cant get it for the default ones…
Create a custom action with the same name as the source button with autofill enabled. It’ll autofill with the default key/source information. Make sure the action and icon autofills correctly, as it may prematurely autofill with the name of a shorter default key/source like y instead of youtube. If it does change the icon and set the tap action to default. From there you can apply CSS styles to it under the appearances panel. See this example in the README.
The new visual editor has me confused a bit. I pasted my old kodi remote config, pressed “Update Old Config” but some things wont work. For eg on the touchpad, tapping once used to send a “return” which was like the “Ok” or “Enter”. That does not work now and gives the error “Action : remote.send_command not found” Similarly I had a double tap mapped to back, that also doesnt work.
I used the visual editor to add few elements and the touchpad in that works fine unlike my old one. But I had my volume buttons in my old config mapped to my AVR and not to Kodi, dont know how to achieve that in the new one. Also unsure how to use double tap and long press in the new one.
Would be very appreciative of any help. Thank you.
My old raw config yaml as below
type: custom:android-tv-card
keyboard_id: media_player.kodi
rows:
- - back
- home
- menu
- - info
- play_pause
- stop
- - - volume_buttons
- touchpad
- - textbox
- null
- search
- null
- fullscreen
long_click_keycode: menu
custom_actions:
- type: button
tap_action:
action: perform-action
perform_action: kodi.call_method
method: Input.ButtonEvent
button: Up
keymap: KB
entity_id: media_player.kodi
hold_action:
action: repeat
icon: mdi:chevron-up
mode: single
- type: button
tap_action:
button: Down
keymap: KB
hold_action:
action: repeat
icon: mdi:chevron-down
mode: single
- type: button
tap_action:
button: Left
keymap: KB
hold_action:
action: repeat
icon: mdi:chevron-left
mode: single
- type: button
tap_action:
button: Right
keymap: KB
hold_action:
action: repeat
icon: mdi:chevron-right
mode: single
- type: button
tap_action:
button: return
keymap: KB
icon: mdi:kodi
mode: single
- type: button
tap_action:
button: backspace
keymap: KB
icon: mdi:arrow-left-bold
mode: single
- type: button
tap_action:
method: Application.SetMute
mute: toggle
icon: mdi:volume-mute
- type: button
tap_action:
method: Application.SetVolume
volume: increment
hold_action:
action: repeat
icon: mdi:volume-plus
- type: button
tap_action:
volume: decrement
hold_action:
action: repeat
icon: mdi:volume-minus
- type: button
tap_action:
method: Input.ContextMenu
icon: mdi:menu
- type: button
tap_action:
method: Input.Home
icon: mdi:home
- type: button
tap_action:
method: Input.Info
icon: mdi:information
- type: button
tap_action:
method: Player.PlayPause
playerid: 1
icon: mdi:play-pause
- type: button
tap_action:
method: Player.Stop
playerid: 1
icon: mdi:stop
- icon: mdi:fullscreen
mode: single
tap_action:
button: Tab
keymap: KB
type: button
- type: touchpad
tap_action:
action: key
key: DPAD_CENTER
up:
tap_action:
button: Up
keymap: KB
hold_action:
action: repeat
mode: single
type: button
down:
tap_action:
button: Down
keymap: KB
hold_action:
action: repeat
mode: single
type: button
left:
tap_action:
button: Left
keymap: KB
hold_action:
action: repeat
mode: single
type: button
right:
tap_action:
button: Right
keymap: KB
hold_action:
action: repeat
mode: single
type: button
styles: |-
toucharea {
height: 400px;
haptics: false
double_tap_action:
action: key
key: back
hold_action:
action: key
key: menu
platform: Kodi
That YAML is in the new format (custom_actions is a list instead of a dict/object). Do you still have a copy of the old config? Your new one is working fine for me on my Kodi dev instance.
Have you read the new README? It has instructions with screenshots on how to use the configuration UI.
Ok, maybe the yaml got written over when I did an Update Old Config.
I can see the descriptive readme but pool old me is having a tough time adapting it to my needs ![]()
Appreciate your help, the old yaml is below. As I mentioned, the only things not working are the center button (single tap), long press and double tap.
keyboard_mode: KODI
rows:
- - back
- home
- menu
- - info
- play_pause
- stop
- - - vol_buttons
- touchpad
- - textbox
- null
- search
- null
- fullscreen
touchpad_style:
height: 400px
enable_touchpad_feedback: false
enable_double_click: true
double_click_keycode: back
custom_keys:
up:
service: kodi.call_method
service_data:
button: Up
keymap: KB
mode: single
down:
service_data:
button: Down
keymap: KB
mode: single
left:
service_data:
button: Left
keymap: KB
mode: single
right:
service_data:
button: Right
keymap: KB
mode: single
center:
icon: mdi:kodi
service_data:
button: return
keymap: KB
mode: single
back:
service_data:
button: backspace
keymap: KB
mode: single
volume_mute:
mute: toggle
volume_up:
volume: decrement
volume_down:
volume: increment
menu:
home:
method: Input.Home
info:
method: Input.Info
play_pause:
playerid: 1
stop:
method: Player.Stop
playerid: 1
fullscreen:
service_data:
button: Tab
keymap: KB
mode: single
- type: media-control
entity: media_player.kodi
Try this, it’s working for me.
rows:
- - back
- home
- menu
- - info
- play_pause
- stop
- touchpad
- - textbox
- null
- search
- null
- fullscreen
platform: Kodi
custom_actions:
- type: button
tap_action:
button: backspace
keymap: KB
mode: single
- type: button
tap_action:
mute: toggle
- type: button
tap_action:
volume: decrement
hold_action:
action: repeat
- type: button
tap_action:
volume: increment
hold_action:
action: repeat
- type: button
tap_action:
icon: mdi:menu
- type: button
tap_action:
method: Input.Home
icon: mdi:home
- type: button
tap_action:
playerid: 1
mode: single
tap_action:
button: Tab
keymap: KB
type: button
- type: touchpad
tap_action:
method: Input.Select
up:
tap_action:
button: Up
keymap: KB
hold_action:
action: repeat
mode: single
type: button
down:
tap_action:
button: Down
keymap: KB
hold_action:
action: repeat
mode: single
type: button
left:
tap_action:
button: Left
keymap: KB
hold_action:
action: repeat
mode: single
type: button
right:
tap_action:
button: Right
keymap: KB
hold_action:
action: repeat
mode: single
type: button
styles: |-
toucharea {
height: 400px;
haptics: false
double_tap_action:
method: Input.Back
hold_action:
target: {}
- type: button
tap_action:
method: Player.Stop
playerid: 1
icon: mdi:stop
media_player_id: media_player.kodi
The upgrade process isn’t perfect, especially for really old configs, so there’s bound to be some issues.
I also don’t think you need the keymap fields in your custom actions, as I don’t include them in the new Kodi default key maps and they work fine without them.
It works. Big thank you!
Keyboard doesnt work. It says androidtv.adb_command not found.
Another peculiar thing I observe is that I am not able to edit the yaml config properly. When I try to edit/ delete some sections, the cursor suddenly just goes to the top left corner of the window, to the beginning of the code. Its as though the visual editor wont let me edit it. Even when I delete the entire yaml I am still able to see the remote in the right preview pane.
Are you sure that your platform is set to Kodi, and that it isn’t overridden by any custom keyboard actions?
The cursor jumping is an issue with the code boxes and appears in some default cards. Which editor mode is this for? The entire card? The layout tab? An action?
The cursor is jumping when editing the entire card. I am left with no option but to create the yaml on notepad and replace the entire contents. When I try to delete a few lines, it does not allow me. This is quite problematic.
Unfortunately that’s a Home Assistant issue, I don’t have control over the entire card YAML editor, just the subsection ones. Can you try and see if it also happens with other custom cards? Why not use the UI editor?
I had forgotten the line
platform: Kodi
Hence the keyboard not working. Got it going.
I can edit the yaml just fine from the raw config editor, but not from the individual card. I had copied the conifg directory of another build to this one in the hopes of copying over all settings etc but that hadnt worked. Then I manually installed a bunch of stuff from HACS anyway. Hope that isnt causing the issues.
since updating my Android TV to version 12, some commands do not work anymore (e.g.
TV,CHANNEL_UPandCHANNEL_DOWN). Other still do (e.g. dpad commands orHOME).
Did someone experience the same issue?
Think, I’ve had the same problem.
Solution: my Bravia Integration has been broken.
Removed it completely and added it again.
Now it works
4.1.0 has been released!
This version implements a massive overhaul of the templating system. Almost all of the Home Assistant templating extensions have been implemented into ha-nunjucks, my instantaneous synchronous frontend only alternative templating system for Home Assistant. This includes Pythonic datetimes! See the ha-nunjucks README for more information on all of the new templating functions, filters, and tests.
This version also adds a new action - Evaluate JS. If you know how to write JavaScript, you can now do so as an action. Just be careful that you don’t break anything!
Can anyone provide insight as to why this isn’t triggering any action, it works in other cards:
platform: Apple TV
custom_actions:
- type: button
icon: custom_icon_0
styles: |-
:host {
–icon-color: rgb(210, 51, 66);
tap_action:
action: call-service
service_data:
entity_id: media_player.masterbedroom
media_content_type: url
media_content_id: >-
Where's Johnny? - The Sopranos (Season 5, Episode 3) - Apple TV
remote_id: remote.masterbedroom
rows: - youtubetv
- touchpad
- volume_up
- volume_down
- home
- Sopranos
custom_icons: - name: custom_icon_0
Read the README, and use the configuration UI. service_data should be data, and call-service should be perform-action. You’re also missing the perform_action (formerly called service) field which I’m guessing should be media_player.play_media. There’s a button on the bottom of the first tab of the configuration UI which will update deprecated configs, including outdated actions (formerly called service calls, renamed by the Home Assistant developers a few monthly release ago) like yours.
Sorry I have a few issues I have not been able to resolve.
remote_id: remote.shield
keyboard_id: media_player.android_tv_192_168_1_233
platform: Android TV
media_player_id: media_player.shield_2
rows:
- keyboard
- search
- captions
- ‘- keboard’ ignores the string and sends ‘i’ only (Android Debug Bridge configured, connected to my Nvidia Shield with the corresponding keyboard_id)
- ‘- captions’ is not working at all, is that a strictly roki feature?
- ‘- search’ initiates google assistant correct string and finds what I need but ends with a voice command/waiting waiting for voice input (locks everything up for a while)
Is there a way to make the touchpad bigger? I can not figure out the code.
keyboard only sending i and search also triggering voice input sound like really weird bugs, but I’m not sure what to do about them since they work fine on my Google TVs.
The Android TV default keys comes from the Python library list. It may not work on all Android TVs.
The width is defined by your card layout and Home Assistant. The height can be changed using CSS styles under the appearance section of a custom touchpad action.
.toucharea {
height: 400px;
@Nerwyn is their a tutorial on how to edit images like this into svg to fit the icon part. I could not find any good youtube videos to help me use this icon for my plex icon.
