Sounds like a HACS path issue, possibly related to HACS v2. You should check your resources list and make sure that the listing for this card is using the new file name /hacsfiles/android-tv-card/universal-remote-card.min.js. and not the old android-tv-card.min.js file name.
Everything was in its place and other HACS installs worked fine. Strangely only this one was being impacted. I verified the filesystem path and it was also correct. Using the new name.
Is it possible to use this with a Chromecast with Google TV without the Android TV Remote integration?
I am having issues with this integration which requires me to remove and re-pair the integration weekly. I have the ADB integration enabled which works fine without needing to re-pair. Can you use this ADB integration for navigation (touchpad, volume, home, back etc.?)
Thanks!
The Fire TV platform uses ADB, try that.
Anyone seeing this issue where icons that have a CSS style applied to them show up blue when the if statement is false? This only happens on iOS and not Mac.
:host {
--icon-color:
{% if is_state_attr('media_player.music_flow_sh7b_3c_8a', 'is_volume_muted', true ) %}
red
{% endif %}
The icons below the trackpad do not have a CSS style applied with an if statement and they show up white as expected.
Itâs an issue with how iOS WebView handles CSS inheritance. Does it still happen if you move the template around --icon-color or define icon color using the icon selector (or a combination of the two)?
:host {
--icon-color: red;
{% endif %}
.icon{
color:
red;
{% endif %}
No luck with either option unfortunately. I tried adding elif statement as below but the icon disappears
</s> <s>:host {</s> <s> --icon-color: </s> <s> {% if is_state_attr('media_player.music_flow_sh7b_3c_8a', 'is_volume_muted', true ) %}</s> <s> red</s> <s> {% elif %}</s> <s> white</s> <s> {% endif %}</s> <s>}</s> <s>
Scratch that using the below worked!
.icon{
color:
red;
{% endif %}
Hi, one of my cards is impacted by breaking changes to V4. I guess I have to replace âtouchpad_styleâ and probably âcustom_keysâ as they are no longer part of the documentation, but not totally sure how to implement the changes.
Would you mind providing some guidance and/or reference to the relevant procedure? Thank you!
- type: custom:android-tv-card
remote_id: remote.rss
rows:
- - touchpad
touchpad_style:
height: 10rem
background: transparent
opacity: 20%
custom_keys:
up:
service: script.rss_headlines_increment
down:
service: script.rss_headlines_decrement
left:
right:
center:
action: url
url_path: |
{% set n = states('counter.news_rss_counter') | int %}
{{ state_attr('sensor.radio_canada_rss','entries')[n].link }}
You need to open your remote in the new configuration UI and click on UPDATE OLD CONFIG at the bottom of the general tab. Itâs mentioned in the v4 post above, the v4 release notes, and the README.
Anyone got working yaml for keyboard to work? Using an ADB device it always says One of entity_id must be provided.
Iâve provided the ADB device like this just to test.
remote_id: remote.living_room_google_tv
media_player_id: media_player.living_room_google_tv
rows:
- keyboard
If you use the configuration UI, thereâs a field for keyboard_id.
I use a yaml config for HA so donât think thatâs possible.
Oops, Missed it. Was expecting manual changes / not used to seeing transition tools like this, great work. Thanks for your support.
Iâm trying to get this set up for my SamsungTV. I was using the TV Remote Card but this seems to have a few limitations - and also looks abandoned.
With the other remote, I was able to add buttons to go immediately to a particular channel. I used the following code to do this:
bbc_1:
icon: mdi:numeric-1-box
service: media_player.play_media
service_data:
entity_id: media_player.kitchentv
media_content_id: '101'
media_content_type: channel
Iâm not sure how I would add that to this remote though.
Also - selecting a source doesnât seem to function either. Not sure what is going on there!
Use the configuration UI! You should just have to provide your Samsung TV entity IDs and set platform to Samsung. You can also add custom actions using the UI for new sources.
With the source, I have added a new button in the UI, but it isnât working. I know there is a native Netfilx button, but this is basically so I can see how to add my other sources. I can select Netflix using the media player source selector (and in my old remote), but this doesnât seem to do anything.
this is the YAML from the new button:
type: button
autofill_entity_id: true
icon: phu:netflix-alt
value_attribute: friendly_name
tap_action:
action: source
source: Netflix
remote_id: remote.kitchentv
So I have managed to create a change source button, however I had to do it using the âPerform Actionâ option in tap behaviour as the âSourceâ option doesnât seem to work. This is the button code now:
type: button
tap_action:
action: perform-action
perform_action: media_player.select_source
source: Netflix
Per the README, the source action is shortcut for remote.turn_on, not media_player.select_source.
Thanks for that!
Absolutely awesome work by the way!! It really is a fantastic remote! Looking forward to building a few more remotes for my other TVâs ![]()
Remember everyone! The current default sources lists for the new platforms are limited, and I could use help expanding them.
