Which Inverter do you own? As I have added it into SPH so far.
Edit: If you are unsure let me know the first 3 digits of “Firmware Version”
(You will have to manually enable it though)
Growatt MIN 6000 TL-XH
Firmware AL1.0
Ok I think I have found the missing registers.
I’ll try and get an update out later today.
Do you have additional sensors on your Inverter / Cloud App for Today’s / Total Grid Charge. In addition to Battery Input / Output?
“Exported to Grid” is the only thing I can see…
Sent DM with dashboard
Just perfect. Thank you so much.
Hi @wills106
It can be possible to have a switch button for fry contact ? To activate or desactivate ?
Or it’s not possible?
(Because the manual or smart is not good when a battery is connected to the inverter)
What exactly are you trying to Turn On/Off? I don’t quite understand what you are asking.
The dry contact switch.
To turn dry contact on or off.
If you have a SolaX Gen4 Hybrid reconfigure the Integration with the DCB (Dry Contact Box) option ticked.
I do it, but I don’t show a open/close switch to do that.
What is the switch name ?
If exist this write in EPROM every time ?
Hey,
So I just got a Solax X3 PRO G2 and thought I would give this HA addon a go. I have the pocket wifi 3 but it doesn’t seem to have port 502 open for modbus querying…
Possibly the inverter is not supported at all, but I’m interested in knowing how to proceed to help out getting it to work?
There is a select called “Dry Contact Mode”
Yes it will write to the EEPROM each time you change it.
Have you checked your on the Minimum Firmware version for the PocketWiFI 3.0
I don’t actually know if the PocketWiFi 3.0 provides Modbus on the X3 MIC / MIC Pro. You might only be able to connect via RS485.
That seems to be it, Solax support replied with that TCP connection was not supported on the X3 PRO
すみません
にほんじんですか
あなたへのおくりもの
SolaX J1:
This is still WIP (Work in Progress)
Upon loading plugin_solax_a1j1 you will get the following error in your log “unrecognized inverter type - serial number : {seriesnumber}”
I need to know the first 4 or 6 digits of the serial Number to understand how the Inverter defines itself.
Sofar:
SolaX Gen4:
Solis:
SRNE:
Sorry, I’m not an expert.
My installation is a Solax H3 Hybrid G4 with Pylontech batteries.
I installed a Waveshare RS485 to Poe Eth (B) by wiring 458A - 458B and GND.
I’ve done the installation via Hacs and I can only find 4 entities
I’ve looked through the post but can’t find any information
Did I miss something?
I got Corab Encore inverter but protocol documentation is same as for Solax Hybrid X1&X3-G3 - do you think I will be able to connect it using your this integration via WaveShare RS485 TO POE ETH ?
Protocol documentation is same as https://www.photovoltaikforum.com/core/attachment/246811-solaxpower-external-communication-protocol-hybrid-x1-x3-g3-modbustcp-rtu-v3-28-p/
