Hello, I can’t install HACS in home assistant OS. I am using the command “wget -0 - https://get.hacs.xyz | bash -” in the command line and it always throws "FATA[0000] Error while executing rootCmd: unknown command “wget” for “ha” " at me. Can someone please help me? Thanks, Bedrich1
Specs: Device RP 4 (128 GB RAM)
32 GB SD
well, that’s what I did. It said that “wget” is an unknown command.
To make it more transparent…as ‘what I did’ can be a lot
But I have the OS version. The HACS site sais that you just type in the command.
@vingerha Thank you so much. I went to the wrong terminal. THANK YOU.
And it works, that is what counts
No clue, did you succeed yesterday?
No, yesterday I just wrote the command and then rebooted my RP4, and according to the guide, it should be there.
Read the link…did you follow clear cache?
yeah, it still doesn’t work
Weird, I installed this numerous times on HAOS and docker, never had issues. Maybe raise it via hacs discord server?
HACS: Help | HACS
