I’ve installed hass.io using these instructions: “https://github.com/home-assistant/hassio-build/tree/master/install#install-hassio”. Works fine so far on a mini-PC!
What I’ve noticed is that if i restart HA from within the webgui, i see a container spun up (I use docker stats
) with random names (last time it was laughing_mahavira
and seems to be always 2 words with an underscore in between). Does anyone know what this is? Is this to be expected or is my installation flawed?
I’ve only installed the hass.io node-red plugin so far b.t.w.
thanks in advance!
Manfred
