Hi everyone, i’ve recently (today) bought a fibaro wall plug (FGWPF-102 ZW5 v3.2) and if i add it to homeassistant through the zwave panel it shows up as unknown device and can’t change any config values.
I had the same problem with the FGWPF-102 ZW5. This is because the python-openzwave package homeassistant uses doesn’t have the config for the newer model and therefore shows up as unknown. I’ve fixed this by manually adding it to my zwcf*.cfg file.
I’ve found the correct file in the openzwave C++ github:
GitHub 1
OpenZWave/open-zwave
open-zwave - a C++ library to control Z-Wave Networks via a USB Z-Wave Controller.
Then i’ve changed the name of the unknown device in the .cfg file
And the i’ve added the values i found on the github between these tags
NOTE: You’ll need to stop homeassistant before changing these values.
