Hi!
I am using HA 2023.11.2 in a docker container an a Debian 11 OS. Today I tried to add a ZigBee stick (ConBee II, used). It registers in dmesg:
[1042362.810365] usb 1-4.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
[1042362.810646] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1042362.810921] usb 1-4.2: Product: ConBee II
[1042362.811184] usb 1-4.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
[1042362.811451] usb 1-4.2: SerialNumber: DExxxxxxx
… and it is shown in lsusb:
Bus 001 Device 022: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
Home Assistant dicovers the device and shows me that I can configure it. If I do so, it takes minutes (while 1 CPU at 100%) and I get an error:
Unknown error occurred
Core log does not show anything related, maybe Supervisor does:
await self._client.close()
AttributeError: 'NoneType' object has no attribute 'close'
23-12-01 14:42:52 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-134436' coro=<HomeAssistantWebSocket.async_send_message() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:250> exception=AttributeError("'NoneType' object has no attribute 'close'")>
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 263, in async_send_message
await self._client.async_send_command(message)
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 93, in async_send_command
return await self._futures[message["id"]]
supervisor.exceptions.HomeAssistantWSConnectionError: Connection was closed
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 265, in async_send_message
future: <Task finished name='Task-134437' coro=<HomeAssistantWebSocket.async_supervisor_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:318> exception=AttributeError("'NoneType' object has no attribute 'close'")>
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 323, in async_supervisor_event
await self.async_send_message(
future: <Task finished name='Task-134439' coro=<HomeAssistantWebSocket.async_supervisor_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:318> exception=AttributeError("'NoneType' object has no attribute 'close'")>
future: <Task finished name='Task-134440' coro=<HomeAssistantWebSocket.async_supervisor_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:318> exception=AttributeError("'NoneType' object has no attribute 'close'")>
Currerntly I am not shure, where to start debugging the problem…
Any suggestions?
Best Pascal
