Unknown error Nest integration
I am installing integration with Google Nest, following this guide:
Everything went exactly as described up until this point:
Link Google Account
In HA, I enter the Cloud Project ID, followed by Device Access Project ID. I am redirected to a Google page where I can give the permission per device. After that screen I am in a screen to select my Google Account. It goes to an unsafe page, just as described in the guide. I continue anyway and give HA access for the two permissions it needs.
I get the question from HA to link my account and I click “Link account”
I then get this pop up, which is not described in the guide:
8-11-2024 23.13.55 0002
The pub/sub topic name is the same as in the device access console, so I click submit. Now I get an unknown error…
I can’t find anything related to this in troubleshooting. Anyone knows how I can fix this?
This is the unknown error I am getting:
8-11-2024 23.07.38 0001
Hey Mick,
I am currently experiencing the same error. This is my first install of HA and I have ben struggling the last few days to get it working with my specific setup.
In general all my “issues” stemmed from the fact that I could never get the Nest integration working. Initially after going through the exact stept you described I did not see this popup that we both have now, instead i just got an empty error popup.
Long story short it was because my internet connection is DS-Lite. So I set up a Cloudflare tunnel and now I got past the first step and I am confronted with this same popup as you have.
looking at the HA Logs I can see that a KeyError with the subscriptions key exists.
How can I completely restart the Nest setup? Because somehow it has saved my authentication even after deleting credentials it immediatly goes to this popup still…
Hi Mick - I’m in exactly the same situation. I’m wondering whether it is the fact that the project can take a little time to fire up?
My plan is to wait 24 hours and try again. However would love to hear if you find a different way to reolve this.
OK so strangely accessing HA from external network gives me a clearer error:
Error talking to API to list eligible Pub/Sub subscriptions: Unauthorized response from API (401): UNAUTHENTICATED (401): Request had invalid authentication credentials. Expected OAuth 2 access token, login cookie or other valid authentication credential.
I think we may need to refresh the credentials or similar. Except when I try that and remove credentials it still shows me this popup when I try and install.
I’m not sure how to completely reset this nest process.
UPDATE: In order to “reset” the google Nest process. Remove all Google Nest related service that were setup during the guide. Then reboot HA. For me the process now starts from scratch. I will continue tomorrow and report.
Let me know what happens!
So I didn’t do anything with this yesterday, today I checked again, I now get a different message “already_in_progress”:
9-11-2024 21.04.13 0001
I restarte HA, and now I am back to the error I posted in my first post.
Hi everyone, I removed my Nest integration yesterday because one of my thermostats wasn’t showing so I thought I would do a fresh install. I spend five hours yesterday trying reinstall the integration and am seeing the same error over and over.
Same error, fresh install :frowning:
Got the same error as everyone here after setting up everything. Hoping for a solution for my Google Nest doorbell.
FIX:
You need to manually create a topic in google cloud here: https://console.cloud.google.com/cloudpubsub/topic. Default settings worked fine for me, and then selected the new subscription in the setup page of the integration in home assistant.
https://www.reddit.com/r/homeassistant/comments/1gmz7kx/google_nest_integration_what_am_i_doing_wrong/
this works! thank you so much!
Henry, you legend. Thank you!
I cannot believe the topic creation doesn’t happen in the setup process or mentioned in the setup steps?
Thank you Sir!
@henryp thanks!! This worked!
De oplossing met een topic aanmaken werkt! Dit was het laatste stapje om mijn nest thermostaat in home assistent eindelijk (2 maanden klojo-en) geĂŻntegreerd te hebben. Dank, dank, dank.
