Hi everyone,
I’m facing an issue while configuring the Nextcloud integration in Home Assistant. Whenever I attempt to configure it, I receive an error message simply stating, “Unknown error occurred.”
Here’s the related log message:
2024-02-04 10:06:49.810 WARNING (SyncWorker_8) [py.warnings] /srv/homeassistant/lib/python3.11/site-packages/urllib3/connectionpool.py:1061: InsecureRequestWarning: Unverified HTTPS request is being made to host '192.168.0.105'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings
I’ve followed the tutorials to set up Home Assistant Core (Install Home Assistant Core on the Raspberry Pi | by Chelaru Adrian | Dec, 2023 | Medium) and Nextcloud, including the certificate (How to Setup a Raspberry Pi Nextcloud Server - Pi My Life Up), as part of my Raspberry Pi setup.
Has anyone encountered a similar issue or could offer insights into what might be causing this error? Any guidance on troubleshooting or resolving it would be greatly appreciated.
Thank you for your assistance!
