I am currently running HA 0.118.4. When I try to update to .5 I get the error in the subject. Any idea?
upating the supervisor before updating to .5?
Not sure. There was just an option to install as shown below and I clicked on it. There was no separate supervisor install option.
Guess this is just me but eventually for some reason 20.12.0 installed after continuous failed attempts. Now with 20.12.1 it’s again erroring.
Should be noted there is nothing in the homeassistant.log log file when I do this.
have same problem with Home Assistant Core 2021.1.4
and logs doesnt have any errors, wtf
disk space is enough
I have also the same problem with Home Assistant Core 2021.1.4
The supervisor is slow with responding (5 minutes), but Grafana is also slow.
In the log there are no error messages.
I use RBP3b with a 240GB SSD. On the SSD is the activity LED flashing continuous.
Apparently we are of the few as no one else is chiming in. I know I can SOMETIMES get around it by rebooting my VM and then immediately updating it. For this latest core-2021.3.2 update that hasn’t been working.
I cant install this addon i am on 2021.9.6
I can see this in the logg
21-09-14 17:54:48 ERROR (SyncWorker_5) [supervisor.docker.addon] Invalid build environment, can’t build this add-on!
Where did you find that add-on ?
I don’t see a reason at first sight :
linux/amd64
linux/arm/v6
linux/arm/v7
linux/arm64
