MISEV
(Niels)
May 1, 2020, 1:12pm
1
Hi All,
I’m trying to update my hass.io to version 0.109.2 that is running inside an Proxmox VM.
When running the update there is an unknown error like below:
So i open the console to retrieve some more info and getting same behavior as this post .
Next step was to repair and update with the console. But I’m now receiving the message already in use.
Anyone else have the same issues or suggestions to try? I’m a little stuck at the moment
Thanks for this amazing community
Regards Niels
Famku
(Famku)
May 1, 2020, 1:35pm
2
Same problem here with hass.io on vmware 6.7 …
increase disk space solved the issue
MISEV
(Niels)
May 1, 2020, 2:58pm
3
Off course, never thought of that. Increasing the disk was also the solution for me.
Thanks Famku for your reply!
Jdruwe
(Jeroen Druwé)
May 1, 2020, 10:30pm
5
When I try to update using the cli I get the following:
root@hassio:~# ha core update
Error: Unknown Error, see logs
If I check the logs I see the following:
root@hassio:~# ha supervisor logs
20-05-01 22:28:22 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.109.2
20-05-01 22:28:22 INFO (SyncWorker_8) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.108.8 to homeassistant/qemux86-64-homeassistant:0.109.2
20-05-01 22:28:22 INFO (SyncWorker_8) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.109.2.
20-05-01 22:28:23 ERROR (SyncWorker_8) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.109.2 -> 500 Server Error: Internal Server Error ("readlink /var/lib/docker/overlay2: invalid argument").
20-05-01 22:28:23 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
I then ran
root@hassio:~# ha su repair
Command completed successfully.
Followed by the ha core update command but then my nuc seems to freeze again.
Any idea?
