Wed Feb 26 2020 13:08:43 GMT-0500 (Eastern Standard Time)
Error handling message: Unknown error
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 221, in async_render
return compiled.render(kwargs).strip()
File “/usr/local/lib/python3.7/site-packages/jinja2/environment.py”, line 1090, in render
self.environment.handle_exception()
File “/usr/local/lib/python3.7/site-packages/jinja2/environment.py”, line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File “/usr/local/lib/python3.7/site-packages/jinja2/_compat.py”, line 28, in reraise
raise value.with_traceback(tb)
File “”, line 1, in top-level template code
File “/usr/local/lib/python3.7/site-packages/jinja2/sandbox.py”, line 407, in getattr
value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: ‘binary_sensor’ is undefined
File “/usr/src/homeassistant/homeassistant/components/websocket_api/connection.py”, line 95, in async_handle
handler(self.hass, self, schema(msg))
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 254, in handle_render_template
state_listener()
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 242, in state_listener
msg[“id”], {“result”: template.async_render(variables)}
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 223, in async_render
raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: ‘binary_sensor’ is undefined
The error seems associated with a particular Lovelace View.
It seems you’re referencing a binary_sensor that doesn’t exist. How is that view defined? Does it reference a binary_sensor, and if so, is there a typo, or is there some reason the binary_sensor you expect to exist doesn’t?
Unfortunately, I have spent many hours searching for the elusive reference(s) to the missing binary_sensor in my lovelace files but cannot find it. Meanwhile, insteon, espHome, and zwave devices create “hidden” binary_sensor entities. In the process of deleteing some of the lovelace binary_sensor references (for testing) I have actually created even more errors.
Ah, I see. It was telling you the variablebinary_sensor didn’t exist, and that’s because you didn’t have it quoted (to make it a string.)
I guess I didn’t look closely enough to see it wasn’t complaining about a particular binary_sensor entity ID (e.g., 'binary_sensor.blah_blah'. It would help in the future if you properly format error messages. As you posted them they were very difficult to read which made it easier to overlook stuff like this.)
