hi guys, I need some advice please. I installed and connected a lot of components to the ESP32 lilin lite with cables. I don’t know, I just think. And the esp32 got into a state where it doesn’t log in to me, it’s still Unknown.
This is my yaml:
esphome:
friendly_name: esp32 lolin kupelna hub
esp32:
board: lolin32_lite
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "mtmfzRHcJWvDh2ahFFL38w77Wn517BL+HVS4jz2ST74="
ota:
password: "f0b89511c3268ac794a2ddb75e04bf7a"
wifi:
ssid: !secret wifi_ssid
captive_portal:
# Example configuration entry
i2c:
- id: bus_a
sda: GPIO22
scl: GPIO19
scan: true
- id: bus_b
sda: GPIO18
scl: GPIO23
scan: true
- platform: aht10
i2c_id: bus_a
temperature:
name: "Kupelna teplota vana"
humidity:
name: "Kupelna vlhkost vana"
update_interval: 1s
- platform: aht10
i2c_id: bus_b
temperature:
name: "Kupelna teplota susicka"
humidity:
name: "Kupelna vlhkost susicka"
update_interval: 1s
- platform: ld2410
light:
moving_distance:
name : "Moving distance (cm)"
still_distance:
name: "Still Distance (cm)"
moving_energy:
name: "Move Energy (%)"
still_energy:
name: "Still Energy (%)"
detection_distance:
name: "Distance Detection (cm)"
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
switch:
- platform: gpio
pin: GPIO26
restore_mode: ALWAYS_OFF
- platform: gpio
pin: GPIO27
- platform: gpio
pin: GPIO33
- platform: gpio
pin: GPIO32
- platform: gpio
pin: GPIO14
- platform: ld2410
engineering_mode:
bluetooth:
name: "Control Bluetooth"
ld2410:
uart_id: ld2410_uart
throttle: 1500ms
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: out pin presence status
number:
- platform: ld2410
timeout:
light_threshold:
name: Light Threshold
max_move_distance_gate:
name: Max Move Distance Gate
max_still_distance_gate:
name: Max Still Distance Gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
button:
- platform: ld2410
factory_reset:
restart:
query_params:
text_sensor:
- platform: ld2410
version:
name: "Presence Sensor Version"
mac_address:
name: "Presence Sensor MAC Address"
select:
- platform: ld2410
distance_resolution:
name: Distance Resolution
baud_rate:
light_function:
out_pin_level:
name: Out Pin Level
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 256000
parity: NONE
stop_bits: 1
thaks for you help guys.
