Hello all,
I use the Wyze smart lock but the auto-unlock feature works about 60% of the time while using an insane about of battery.
I’ve been using Home Assistant as a device tracker via GPS for a while and for the most part, it work really well with less battery usage.
I wish to use HA to unlock the Wyze lock when a device comes home but with a condition that the phone must be away from the home zone for x minutes to prevent HA from unlocking the door if the phone just bounces out of the zone for a few seconds.
I’ve created the following automation:
alias: Unlock side door when X get home
description: ""
- platform: state
entity_id:
- device_tracker.phone_gpslogger
to: home
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sun
- sat
after: "06:00:00"
before: "22:00:00"
- condition: and
conditions:
- condition: state
entity_id: device_tracker.phone_gpslogger
state: not_home
for:
hours: 0
minutes: 2
seconds: 0
- service: lock.unlock
data: {}
device_id: 11e1b77295609d2427a94aab098c4c0f
mode: single
It’s pretty simple but the issue is when the user gets home, the automation doesn’t trigger because the condition of state: not_home
for 2 minutes is no longer valid.
What would be the best way to have HA unlock my door but only if a device has been away from home for at least 2 minutes?
Thanks!
Instead of the state condition, try a template condition that checks trigger.from_state.last_changed
. Also, you don’t need to specify the and condition, which is the default for a list of conditions. So something like:
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sun
- sat
after: "06:00:00"
before: "22:00:00"
- condition: template
value_template: >
{{ (now() - trigger.from_state.last_changed).total_seconds() >= 120 }}
Basically when the trigger fires, it will create a variable called trigger. For a start trigger, it has a field called from_state, which is the state the entity changed from (i.e., it’s last state.) The last_changed field of that state records when it changed to that state. So, we’re testing how long ago the entity changed to its previous state (i.e., the state it was in before it changed to home and triggered the automation.)
Thanks for the suggestion! I will give that a test and see if the action triggers when I arrive at home tomorrow.
Cheers!
Unfortunately, that didn’t work. Here is the trace but it seemed to fail at the value_template:
I have never used vaule_templates before and I am unfamiliar with the syntax.
Any suggestions would be greatly appreciated!
alias: Unlock side door when xx gets home
description: ''
- platform: state
entity_id:
to: home
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sun
- sat
after: '06:00:00'
before: '22:00:00'
value_template: '{{ (now() - trigger.from_state.last_changed).total_seconds() >= 120 }}'
data: {}
mode: single
