I have been reading the thread and it seems like I should have buttons to power down the system and to reboot the system. However I do not! I also do not see any unraid services in HA/Developer Tools/Actions
What am I missing?
I am running HA on bare metal at version 2025.12.5
I have your integration version 2026.01.0 installed
This, I´m also looking for a way to automate the shutdown of my unraid server in ordner to make it more power cost efficient. The turning on is resolved with a smart outlet and bios recovery on power loss but I don´t have a simple clean way to shut it down. Been looking for it in this integration and can´t find it as well? Was this removed?
It’s unclear to me why as a user I should choose ha-unraid or ha-unraid-management-agent the other integration method, can anyone give some insights?
The feature set seems identical except for the authentication method, API vs Unraid Plugin.
Furthermore, the ha-unraid asks for ADMIN level access which is understandable for controlling Unraid, however, it would also be nice to have a VIEWER level compatible access for monitoring only.
The ha-unraid-management-agent integration and Unraid management agent plugin have more features. It has MCP support for GitHub Copilot, Claude, WebSockets for streaming. Planning to add Prometheus support.
@ruaandeysel - amazing work, just see the latest change log. Thank you for the ability to turn things off and slow other items right down. Fits my slow checking needs so much better. Will be doing some fine tuning with this in the next few days.
Hello, I have a problem, I deleted my two servers from the plugin, when I try to put them back, one works without problems. The other one gives me the following error: This Unraid server is already configured.
But within the plugin, only 1 appears. I have tried deleting the unraid plugin from hacs and reinstalling it… Any solution? Thanks¡
Hey @ruaandeysel Since the start of the month after updating Home Assistant and your plugin in HACS, I can no longer run "user scripts". I'm getting the following
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:334
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:52:57 AM (1 occurrence)
Last logged: 12:52:57 AM
[545676650400] Error during service call to button.press: Failed to execute user script: MoriaBackupAndShutdown
@ruaandeysel I finally got around to installing this agent and it works great but I’m also getting the same error trying to run user scripts. Is there something I’m missing…like a permission setting or something?
