jurk
(georg)
June 30, 2021, 8:36am
1
Hello Friends - I have 2 problems with ESP or I don’t even know if not with the whole HA:
On one of the ESPHome in the bedroom, one entity is not visible in hass - the dallas temperature measurement, but on the LOG itself in ESP everything works, I tried to change different names, and even change the whole ESP, but it does nothing - given a new name for this sensor is NOT seen ANYWHERE except log inside ESP
I have another ESP in the bathroom that once added to hassio worked fine, but the entities for some time are no longer visible in full, just like before - all entities are visible in the log but hassio himself sees these entities as unreachable. As before, I changed ESP discs, but it doesn’t do anything
Can’t understand, has anyone had a hit like this ?? …
tom_l
June 30, 2021, 9:09am
2
Can you share the full (sanitised) esphome configuration for both devices?
jurk
(georg)
June 30, 2021, 9:45am
3
Once again - all entities are available in ESP Logs but not seen in HASSIO
Here is all unreachable:
esphome:
platform: ESP32
board: mhetesp32devkit
wifi:
reboot_timeout: 60min
networks:
- ssid: "*****"
password: "######"
ap:
ssid: "Hub Lazienka 3 Fallback Hotspot"
password: "XuaKOUP2dw6f"
captive_portal:
logger:
api:
password: "password"
ota:
web_server:
port: 80
dallas:
- id: "dallas_1"
pin: GPIO14
update_interval: 90s
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: 0
hours: 4
days_of_week: MON-SUN
then:
- switch.toggle: restart_switch
switch:
- platform: restart
- platform: gpio
pin:
number: GPIO17
inverted: false
- platform: gpio
pin:
number: GPIO2
inverted: true
- platform: gpio
pin:
number: GPIO13
mode: INPUT
inverted: True
output:
#wentylator lazienka
- platform: ledc
pin: GPIO15
frequency: 25000 Hz
inverted: True
min_power: 0
#dioda do wentylatora
- platform: ledc
pin: GPIO16
frequency: 25000 Hz
inverted: True
light:
# wentylator
- platform: monochromatic
output: wentylator_lazienka_output
default_transition_length: 0s
output: blue_output
- platform: dallas
address: 0x7500000CFF393828
dallas_id: dallas_1
# update_interval: 45s
- platform: dht
pin:
number: GPIO4
mode: INPUT
temperature:
# filters:
# # - lambda: return x * (5.0/5.0) - 4;
# - lambda: return x ;
accuracy_decimals: 1
humidity:
# model: AM2302
model: DHT22
update_interval: 48s
# Example configuration entry
- platform: ntc
sensor: resistance_sensor
name: NTC Temperature
calibration:
b_constant: 3970
reference_temperature: 25°C
reference_resistance: 14kOhm
# Example source sensors:
- platform: resistance
sensor: source_sensor
configuration: UPSTREAM
# configuration: DOWNSTREAM
# resistor: 26.3kOhm
# resistor: 14.4kOhm
resistor: 18kOhm
# resistor: 2.2kOhm
# reference_voltage: 5V
reference_voltage: 3.3V
on_value_range:
- above: 6000
then:
- switch.turn_off: Kaloryfer_podloga_2
- platform: adc
pin: GPIO32
attenuation: 11db
update_interval: 75s
# filters:
# - multiply: 2
climate:
- platform: bang_bang
sensor: lazienka_kal_temp
default_target_temperature_low: 37 °C
default_target_temperature_high: 40 °C
visual:
min_temperature: 16 °C
max_temperature: 50 °C
temperature_step: 0.5 °C
heat_action:
- switch.turn_on: Kaloryfer_lazienka_2
idle_action:
- switch.turn_off: Kaloryfer_lazienka_2
sensor: lazienka_went_humid
default_target_temperature_low: 60
default_target_temperature_high: 65
visual:
min_temperature: 16
max_temperature: 100
temperature_step: 1
heat_action:
# - light.turn_on: went_dioda
- light.turn_on:
brightness: 0%
- light.turn_on:
brightness: 0%
idle_action:
# - light.turn_off: went_dioda
- light.turn_on:
brightness: 50%
- light.turn_on:
brightness: 50%
sensor: ntc_emperature
default_target_temperature_high: 40°C
visual:
max_temperature: 45 °C
heat_action:
- switch.turn_on: Kaloryfer_podloga_2
idle_action:
here is only Dallas missing:
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "d7371623a6f84aa9cce5b863413f64be"
wifi:
ssid: "user"
ap:
ssid: "Hub-Sypialnia33 Fallback Hotspot"
password: "8UVVuJ1XnREM"
captive_portal:
web_server:
port: 80
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
i2c:
sda: 21
scl: 22
scan: True
time:
uart:
rx_pin: GPIO1
tx_pin: GPIO3
baud_rate: 9600
dallas:
- id: "dallas_11"
pin: GPIO16
update_interval: 40s
- platform: dallas
address: 0xDD00000CFE84BA28
dallas_id: dallas_11
- platform: mhz19
co2:
# filters:
# - lambda: return x - 700;
temperature:
update_interval: 70s
automatic_baseline_calibration: true
entity_id: sensor.outdoor_temperatura
binary_sensor:
name: "gerda doors sensor"
entity_id: binary_sensor.0x00158d00044b72dd_contact
switch:
- platform: gpio
pin:
number: GPIO0
inverted: false
climate:
sensor: syp_kaloryfer_temp
default_target_temperature_low: 22 °C
default_target_temperature_high: 22.5 °C
visual:
max_temperature: 35 °C
heat_action:
- switch.turn_on: kaloryfer_sypialnia_1
idle_action:
- switch.turn_off: kaloryfer_sypialnia_1
display:
- platform: max7219
intensity: 0
cs_pin: GPIO15
num_chips: 3
lambda: |-
auto time = id(esptime).now();
if(time.hour<10)
it.printf(16,"0%d.",time.hour);
else
it.printf(16,"%d.",time.hour);
if(time.minute<10)
it.printf(18,"0%d",time.minute);
else
it.printf(18,"%d",time.minute);
if(id(gerda_sensor_helper).has_state()){
if(id(gerda_sensor_helper).state==1)
it.printf(20," CLO");
else
it.printf(20," OPE");
if (id(sypialnia_CO2_).has_state()) {
it.printf(0,"%4.f", id(sypialnia_CO2_).state);
if(id(outside).has_state()) {
it.printf(8,"%3.1f", id(outside).state);
# if (id(sypialnia_temperatura).has_state()) {
# it.printf(12,"%4.f", id(sypialnia_temperatura).state);
jurk
(georg)
July 2, 2021, 7:37am
4
FIXED! Just removed integration and add another the same - works!
