Unreliable automation triggers by iPhone tracker zones
Is there a more reliable way to automate stuff when coming home. Currently I have seperate day and night automations looking at exiting a zone with a condition the phone is in another zone then starts the automation sequence. It works 50-60% of the time but randomly fails at the zone hurdle. The two zones overlap so the I’m in the final zone while exiting the first zone, this only happens when travelling towards home hence it will no triggers when leaving home as the zones trigger in the opposite order. Not sure if it’s just a limitation of timing and how to get around that so it works every time? The phones in question have companion app to be tracked “always” both iPhones, I know the automatic is correctly configured as it works mostly, but here and there fails at the zone / zone conditions part then stops the sequence. Any ideas? I need it to trigger about 700m from home as one of the 10 actions in the automation is to open the gate which take about 15s to open.
Once again,
Cheers for any advice given
