Unreliable InfluxDB size sensor
All going swimmingly.
So, to wrap it all up. Use this init_command in the SSH & Web Terminal addon with protection mode disabled:
init_commands:
    while [ 1 = 1 ]; do docker exec addon_a0d7b954_influxdb du -s
    /data/influxdb/data/homeassistant >
    /config/file_sensors/ha_influx_db_size.txt && sleep 300; done &
Then create this file sensor:
- platform: file
  name: 'InfluxDB HA DB Size'
  file_path: '/config/file_sensors/ha_influx_db_size.txt'
  unit_of_measurement: 'MB'
  value_template: "{{ (value.split('\t')[0]|int/1000)|round(3) }}"
You can then disable the InfluxDB internal database if you wish (recommended by InfluxDB).
To do so, in the Influxdb addon configuration add this:
envvars:
  - name: INFLUXDB_MONITOR_STORE_ENABLED
    value: "false"
Don’t expect it to be as active as the shard method. I only see an increase every day or two.
