Unresponsive Home Assistant after reboot
I have a strange issue , my HA , 1 or 2 minutes after reboots , starts ok , and then it becomes Unresponsive, network is up and i can ping it, 8123 port is not reachable (telnet closing connection also) ,
Home Assistant observer all fine!
|Supervisor:|Connected|
|Supported:|Supported|
|Healthy:|Healthy|
Any ideas to resolve the issue ?
Another strange , i have uptime kuma installed as addon and it’s working on port 3001 even HA port is down
Hi Nikolas, did you check the logs?
Was you system running fine before and did you change/add/update something?
i took the backup and i will restore it to a VM to check if the same behavior , logs says nothing strange.
Update: The backup is working fine on the VM!
Good you got it solved!
Please take the time to mark your post as the solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so this prevents that someone else steps in to try to help.
