Sometimes it will lose the name of the device (sometimes it just says a weird manufacturers name) and other times it just gets reported as “dead”
Even when it is correctly identified, I am unable to actually lock or unlock the device. Nothing happens when I press the button. I am wondering if maybe this is because of the network key? Although I added one on both integrations and get same behaviour…
I get the exact same behaviour regardless of if i am running the open zwave beta integration or the regular home assistant behaviour. I have tried healing the network and added/removed the device about a dozen times.
i am wondering what could cause this? my only theory is signal strength, but I am not sure how to test that?
I use open zwave in HA and it provides a sent failed/rcvd count for each zwave device in developer tools>>states. Lots of failed messages has been a pretty good indicator of signal issues for me in the past.
I had issues with two of the Yale locks you have. The secure connection doesn’t seem to like to pass through a repeater. I tried to even secure connect a few repeaters to no avail. I ended up just putting an old SmartThings hub near the locks and connecting to them without a zwave repeater. Yes, it goes through the cloud that way, but has worked really well.
