Unsecure https access
I configured my auth_providers as discribed in the docs to get access without login on my digital signage pc.
homeassistant:
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.0.0/24
- 127.0.0.1
- ::1
allow_bypass_login: true
- type: homeassistant
And it works without enter a login from LAN
After that I created an https access with Nginx Proxy Manager for the mobile app and it works too from WAN
BUT - after weeks I checked it from my work and can see that it is possible to enter the site WITHOUT a login!
Can someone tell me my mistake?
thanks in advance
At a guess your proxy is on 192.168.0.0/24, so any traffic that comes through it doesn’t need to login.
Hmm, you are right
so, it is not possible to set https without auto login from WAN and internal with auto login?
it is. You just need to set
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 127.0.0.1
    - ::1
  ip_ban_enabled: true
  login_attempts_threshold: 5
(IP_bans optional)
perfect, I didn’t know that
thank you very much for your help!
