Unsuported system
Hello all
I’m getting a nagging message when I updated today my Home assistant supervised to 2023.1.7. I since clicked to ignored the message and the message is gone.
what is incorrect with my configuration?
I’m running HA on debian 11 within docker. Here below is a coy of my settings
System Information
version core-2023.1.7
installation_type Home Assistant Supervised
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.7
os_name Linux
os_version 5.10.0-20-amd64
arch x86_64
timezone Europe/Rome
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.30.0
Stage running
Available Repositories 1261
Downloaded Repositories 12
HACS Data ok
Home Assistant Cloud
logged_in true
subscription_expiration 27 October 2023 at 02:00
relayer_connected true
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled false
remote_server eu-central-1-2.ui.nabu.casa
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Debian GNU/Linux 11 (bullseye)
update_channel stable
supervisor_version supervisor-2023.01.1
agent_version 1.2.2
docker_version 20.10.22
disk_total 232.7 GB
disk_used 30.1 GB
healthy true
supported failed to load: Unsupported
supervisor_api ok
version_api ok
installed_addons Samba share (10.0.0), File editor (5.5.0), Terminal & SSH (9.6.1), Studio Code Server (5.5.2), MariaDB (2.5.1), Alsa & PulseAudio Fix dev version (3.5), Alsa & PulseAudio Fix (3.4), Node-RED (14.0.1), Genie (3.0.0), Z-Wave JS (0.1.74)
Dashboards
dashboards 2
resources 2
views 8
mode storage
Recorder
oldest_recorder_run 16 January 2023 at 17:29
current_recorder_run 26 January 2023 at 11:07
estimated_db_size 472.91 MiB
database_engine sqlite
database_version 3.38.5
Thank you for your patience
