I have a template sensor that is throwing an error when it tries to update. The error is
Update for sensor.calendly_event_offset fails
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 220, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 375, in async_device_update
await self.async_update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/template/sensor.py", line 191, in async_update
self._state = self._template.async_render()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/template.py", line 191, in async_render
return self._compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
Thanks! I never realized how helpful the template page is for troubleshooting. The issue (at least for now) is that I was trying to subtract one time from another time, but one of the calendars didnât have any events, so instead of returning a time it was returning âNoneâ.
I want to see how this works over the next week before I declaire this officially fixed, but I ran some tests this evening and it appears to be working now.
Where is your template defining the variable called st?
Thisâll also do the trick:
value_template: >
{% set st = state_attr('calendar.nick_calendly', 'start_time') %}
{{ 'on' if st != None and as_timestamp(st) - now().timestamp() < 180 else 'off' }}
I have the same error message but canât see any indication which template is causing it, any ideas on how to find which one is producing this ?
2019-05-28 08:06:13 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/automation/__init__.py", line 280, in async_trigger
if not skip_condition and not self._cond_func(variables):
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/automation/__init__.py", line 401, in if_action
return all(check(hass, variables) for check in checks)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/automation/__init__.py", line 401, in <genexpr>
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/condition.py", line 352, in template_if
return async_template(hass, value_template, variables)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/condition.py", line 331, in async_template
value = value_template.async_render(variables)
TypeError: unsupported operand type(s) for -: 'float' and 'NoneType'
Haha. Thanks everyone! Iâm still learning, so for me my goal is to get something working. I wasnât thinking about optimization, but Iâll update it!
@Holdestmade - Again, for me I had two times that I was subtracting from one another, but in my case one of my values was returning âNoneâ instead of a time since that calendar had no events on it.
To figure out which one it was I copied my entire value_template into the template editor in Home Assistant, which is down with the developer tools at the bottom of the sidebar.
Then, I edited that block removing all of the code around the two variables that I was trying to subtract from one another. So I started with:
For me, that top one (nick_calendly.attributes.start_time) was the calendar that had no events and was returning âNoneâ instead of a time, so I added the additional logic to check for that first and return âoffâ if it didnât have any events.
So to get this working I had also setup a sensor called date_time that just returned the current time every minute and was using that in my calculation for this. It looks like you have replaced my need for that using now().timestamp().
I just wanted to verify that I should be able to delete that date_time sensor all together (since it was created just to get this to work) and this template value will still update itself every minute.
Thanks for the reply but my first issue is finding which template is causing the error, I have many and everything seems to work OK, just getting that error in the log every now and then. I see from your log you have âUpdate for sensor.calendly_event_offset failsâ but in mine it just says âError doing job: Task exception was never retrievedâ
I guess I could just go through all until I find it !
Oh yeah, sorry about that. I have no idea why your error doesnât show the specific template like mine does. Good news is that you should be able to narrow it down to templates that have some kind of subtraction in them. ÂŻ\_(ă)_/ÂŻ
Found it. It was a time condition in an automation checking the last_triggered attribute and when HASSIO is restarted or just automations reloaded, the last_triggered gets set to None. Obvious now but you canât subtract a None from a time.
Thanks for your help, I didnât even notice the subtraction symbol in the error message, thought it was just a hyphen ! and that enabled me to look through just the subtract templates.
After a restart, an automationâs last_triggered attribute remains at whatever date/time it was previously triggered. If it was never triggered then the attribute will be set to null (which is represented for templating purposes as None).
In the following screenshot, âhyphen_testerâ was triggered yesterday. When Home Assistant was restarted today, the automationâs last_triggered displays yesterdayâs date/time.
In contrast, âboolean_testerâ is an automation I used a long time ago then commented it out in the automation file. Today I uncommented the code, restarted Home Assistant and the automationâs last_triggered is null.
The only substantive difference from your configuration is neither of my two systems (production and test) use hass.io.
Production:
arch
i686
dev
false
docker
false
hassio
false
os_name
Linux
python_version
3.6.7
timezone
America/redacted
version
0.89.1
virtualenv
true
Test:
arch
x86_64
dev
false
docker
true
hassio
false
os_name
Linux
python_version
3.7.3
timezone
America/redacted
version
0.91.0
virtualenv
false
I have many automations on my test system. I create them while helping solve problems for community members, then I comment them out in the automations.yaml file. Here are three automations on my test system. Two of them were previously commented out and were uncommented for this experiment (then the test system was restarted). Those two appear with last_triggered = null.
I triggered the two automations (not manually from the Services page but via their defined triggers) and the States page shows their updated last_triggered attribute.
As per the scientific method, the existence of black swans disproves the theory that all swans are white. An automationâs last_triggered attribute can survive a restart/reload.
Now is it because both systems arenât hass.io or is it due to something else?
