Unsupported platform: time_pattern
I updated to 86.4 from 85.1 Now the unsupported platform message appears in the automation editor. Also, the “time_pattern” platform does not appear as a choice when selecting a trigger in the automation editor. When I edit the automations.yaml file, the check config says the config is good but the unsupported platform message appears in the automation editor.
Can anyone suggest a fix?
I guess HA didn‘t update, check the info tab in dev-tools for reported version.
Many thanks! You had it nailed.
Cheers
